Too add, EVGA seem to make a better product. KFA2, in particular the SOC was nowhere near the quality of this Card.
I ordered a backplate for mine, which should be here for Monday. I'll post pictures when I fit it.
Okay, you will need the Maxwell BIOS tool and the version of nvflash that does not check for certificate's. Dr Google those and post screen shot of your voltage table from the Maxwell tool.
When I get home I'll help you more.
I've got them both, I'll get the screenshops up tomorrow, I'm just about to stick a film on downstairs.
Okay, sounds good to me. Enjoy the film.
I've downloaded Maxwell Bios Tweaker from the following link and all seems OK...
http://www.overclock.net/t/1513920/official-nvidia-gtx-980-owners-club/3870#post_23088391
However, when I try to download NVFLash v5.206.0.1 from the following link, Google Chrome steps in and refuses the download with a warning about Malware..
http://www.overclock.net/t/1521334/official-nvflash-with-certificate-checks-bypassed-for-gtx-970-980
Is the Chrome warning a false positive?
I used the same link and Chrome issued the same warning. I used IE then preformed a virus scan on the zip, then the contents just to be sure.
So, the top three would need to be changed e.g
Top line 1262.5 - 1262.5. To the voltage you want (max is 1.3 I beloeve) for both values.
Second line change the right value only
Third line, change the right value only.
P00,P, change the right value.
i did not change any other clk vaules as there where higher than what I set above. Is seems that the top three are a reference the card uses during the other clk vaules and determines if the voltage slider in AB or what ever you are using actually does anything. Eg, my card had a hard limit of 1212, which the card hit right away. So, changing the sliders did nothing for me until I changed it.
Looking at your table, you already have a max of 1262 ref, which is higher than the 1250 I've set, so do you need to raise yours?
If you do, do so at your risk (kinda goes without saying) and ensure that you disable the card in device manage and turn off any firewalls and av during the flash.
What card did that bios come from, I'm sure you said a FTW?
Here is my finalized BIOS for power/temps and volts
EVGA 980 GTX 2.0 AX SC
http://s000.tinyupload.com/index.php?file_id=74072246782581212912
1.3 volts - whats the temps like?
I think we have a bit more to learn with these.
James and Blunderwrapper(?) are the best people for this, but they haven't replied![]()
