What is the best software to overclock the cards ?
Do you think this will power gta5 at 4k?
Just ordered a titan x from overclockers. It will be replacing a 7970 crossfire set up. I have the 40 inch philips 4k monitor. Have I made the right move? I don't think my crossfire setup was working that well, I think I might have had a faulty card.
I also bought a new case and power supply. I will be buying a new x99 board, processor & ram next month when I can afford it.
The titan will be working with a 2600k processor, 16gb ram and a clean install of windows 8.1.
Afterburner.
I have used PX and adding voltage results in instant crash (guessing buggy software) and I have used Asus GPU tweak and pretty boring.
forgot to photo mine when i got it but i'm certainly in the owners club, this card is destroying my old 780 sli
i maybe wrong here but i think you maybe bottlenecked by the 2600k as pci-e 2.0 and 4k don't mix so well
Does the latest version of Afterburner support extra voltage for the Titan Xs.
At the moment I have been using an old version of AB that I used on my 290Xs.
No Kaap but I expect it to in the next iteration, so not long. I don't really want to touch voltages either till I am on water, as I imagine it will get quite warm lol.
Same here - wont touch volts till under water. Where's dem darn blocks, we need blocks.......
Mark
Yer, I haven't even considered ordering mine yet but will make sure they are on water before the hotter weather gets here.
I have got the blocks but I am not looking forward to messing around with all those thermal pads and cleaning off old paste.![]()
What monitors you lot have ?
Nvidia GTX Titan X 4K Gsync Review by TTL @OC3D
That guy really needs to write a script...He does my head in with his pointless rambling...
He's an uneducated moron.
