Well my S34E790C turned up today.
Pleased to report no dead pixels and backlight is very good also.
First thing I done was calibrate it with with my i1 display pro and the colours/brightness are all looking really good now.
The more I am using it the more I'm getting used to the curve. After a little while you forget its there. Kinda strange! lol
BF4 is truely awesome, really immersive experience for sure. That I am liking a lot.
Its a nice jump up from from a 27" 1440p.
I like the extra desktop area, that comes in real handy for work stuff.
So far so good.
General consensus regarding the curved screens, how have you found adjusting to this type of monitor?
I'd also like to know what the viewing distance is like from the other side of a bedroom for example. I'm looking to replace my 27" 1440p unit with one like this but it would also be used as a TV.
Prochaos...My profile probably would have looked very wrong on yours. Iv had three of these samsungs and each one had to be calibrated very differently with different settings in the end. If I was you I would do that a couple more times to try and get it even closer to 6500K. Mines at 6501K since I last calibrated it and while it wont be much of a difference from 6532 id bet you can get it even closer and even more accurate.
What I did myself was pick the largest colour patch that take 7 minutes to do. But set the RBG levels yourself on the monitor...you should be able to get them to 6500k or very close without even running the actual patch calibration and then just let the program finish it off with the patch calibration. Where your RBG colours in a straight diagonal like together at the end when you looked at the measurement graph? that's a good way of seeing how accurate the red green and blue are and if one colour deviates out then you will likely have a slight tint of that colour.
Did they say the reason it was a B-Grade monitor ?
How do you find them at a further distance? Like using it as a TV from a bed.
