And its worth it , highest temp so far I've seen is 37 degrees !
I'm wondering how could I print my picture in this thread I would like to take part in the benching ?
HI, Greg and kappstad I wanna submit a new score
I use evga x found it clocked my gpu higher than msi. also what third party program would you recommend, as ive never seen that file format before.
If you want to use *.tga files there are free openers that you can download and use to convert them to jpeg files.
I use one called "TGA Viewer".![]()
4790 4.7 - Titan X 230/510 Air ( 74-76c max )@ (65%fan) 1.037v 110%pw
For the scoreboard you need to turn off the integrated graphics.![]()
