- 30 Nov 2010
- UK
Video from the second battery, made the mistake at the end of forgetting that I can pull back too far and also being blind.
I would try different props first, like you say could be very unbalanced but you would probably notice that on the video. If it flies ok I wouldn't worry about it I always mute the videos they all sound terrible IMO.
I dont know, iv not had this 250 long, someone suggested gemfans.
I guess they cost a little less too, maybe will look at HQ, when I am breaking less props during sessions
Could the cheap diatone props im using now be causing this in flight vibration assuming the balance is rubbish on them? and the noise? As I said to others on here yesterday, iv been over my model, and nothing is loose
Only thing I can spot is one of the arms has a slight thickness increase on the others. Manufacturing thing by the looks
