So, using these to store and stream media? Surely they'd cope with that.
They are perfect for storing and streaming media, but recommended not to use RAID (just use as single drives).
24/7 a no no ?
Personally I would use this for videos and such, but not so much for games. Stuff that wont be accessed often or not many writes and rewrites. But then I do the same on all large drives, mainly because I tend to buy slightly cheaper and slower drives.
No, this is not a slow drive for R or W but it does have a suggestion that it isn't suitable for high write capacity (i.e. better for archive than work/scratch usage).
Based on the findings at StorageReview, and as I would expect for a SMR drive, sustained write speed is significantly slower than read speed and compared to write speed of a non-SMR drive. The review indicates good burst write speeds with this drive, but I wonder if this drops when the drive is getting full and has higher workload of extra writing for overlapping data.
StorageReview website review is completely flawed and to be disregarded - for our purposes, that is unless you make use of hardware RAID or pseudo hardware RAID (as in firmware based).
These drives have a 25GB flash storage area that is extremely intelligent, when used with a hardware RAID controller this flash area isn't used and the logic built into the drive to compensate for being SMR based isn't able to be used.
Sustained sequential writes are perfectly normal, 180MB-85MB real world.
The RAID rebuild test they did was on a live system as well as the above.
In a word, ridiculous test conditions for an SMR drive that nobody in their right mind would use the drive in, though it does highlight that the drives really are useless in a hardware RAID setup. They perform quite reasonably in a ZFS/RAIDZ1/2 type situation where the logic in the firmware isn't bypassed.
Scrubbing takes much longer but these drives are perfectly fine in a 100% software RAID/ZFS setup for media storage etc. Currently have 8 in RAIDZ2, rebuilds are not the "10 days" people have been talking about. You're talking 2.5-3 days, which is on the very slow end, but not unuseable.
FYI, Seagate continues it's great rep for HDDs. One of mine failed within 33 days of use... Luckily no important data on it or data I don't have elsewhere but still... Great quality!!!![]()
I have a external 3TB HDD for a good few years now and never had a issue with it.![]()
And all 3 Seagate drives I have owned in last 6 years have failed (2Tb External, forget the 1st, this 8Tb)... and I own 4 "working today" 8Tb drives... I am getting worried!![]()
