weird. can you take a picture of the other issues?
The rest are single stuck pixels, like this:
which country did you order yours from? it's odd, as i've seen some reports around of dead pixel problems but they seem to be mostly from mainland Europe. people in UK and USA who have got one so far seem to be experiencing much better quality control and very few issues. i wonder if there's a particularly bad batch somewhere or some European retailer has bought some B-grade / low grade stock and passing them off that way?
Germany. It's a well-known EU retailer (authorized seller for many major hardware brands) so I don't think B-grade stock is the issue. It's only my bad luckI already sent it back... I just hope to have the replacement in time for GTA V.
So whats the verdict on this against the swift
Everything I have read suggests the Swift has a much better build quality but the Acer wins on the screen panel type quality.
This is a picture:
This is like 7-8 stuck pixels right next to each other.![]()
A head and neck ahead of the Swift.
Well monitor is all about what you see on the screen
That is dust between the backlight and the LCD plane.
so it's a no brainer to choose this over the swift? I care about the display not the build quality as much
Do i get this over the swift? i don't nodoes the 4ms over 1ms make much difference?
ArmA 3 does have some weird blurring (not the in-game blur from the options menu), however I'm not sure that game runs at 144Hz when playing? I need to investigate further.
