Looking to get a new ROG myself... but the horror stories scare me. I hope you get a good one mate![]()
It was only after I'd purchased one, that I started reading the stories about problems people have been having
It was only after I'd purchased one, that I started reading the stories about problems people have been havingthe one I have bought is a brand new rma replacement, only opened to check it's working, so fingers crossed I'm safe
No point letting the "horror stories" scare you off.
Great monitor and the failure rate won't be that high... you just hear more about the failures than people happy with their purchase, generally.
You have warranty, you have return to merchant available early on easily too... you'll get one that works well. Worst case you just have to go through a couple of dodgy ones. But you have that risk with any monitor...
Fingers crossed for you![]()
CheersJust setup, everything looks good so far. 2560 x 1440 with Gsync enabled, getting 145fps in COD AW, so used to playing with 250fps @ 2560 x 1920 lol, haven't got my Titan X's yet and still using my 970
Latest Nvidia Drivers :
These new drivers keep Gysnc on in the Rog Swift all the time including general desktop. Even in window mode. I dont know if its a bug or a new feature.
But if your monitor is 144hz you literally can't see anything above 145? Surely?
Anyway to stop gsync from changing FPS? I find 120Hz and ingame fps set to 250, this gives the smoothest gameplay, I don't like playing cod at 145 or 120 FPS :/
Hi it's me again! Still loving my swift! But I'm looking to add a second 4k monitor as a daily main driver but still keeping the swift as my gaming monitor. Is it possible to set my 4k monitor for daily usage and games to show up on the swift as the second?
Would there be any issues I should be aware of? Is there any performance hit or anything funky going on with g sync when running two different monitors at the same time during gaming?
Most people's ability to take advantage of extra information visually drops off above around 80fps ish even - very few people really gain much above ~120Hz/fps in that regard but that isn't the only advantage of rendering at a higher framerate. Even ignoring "magic" physics and all that games can feel smoother with certain combination of settings, etc.
