I ordered mine on the 18th March and Ive still not got them![]()
Hopefully soon.
Not quite as long as yours but I ordered mine around about the 28th, there seems to be a severe backlog with that particular card.
Cancelled my order today, 780 has done better then I thought at 1440p so I’m going to wait and see what the TI card brings and decide between that and a Titan then.
Prime example of what happens when you sit on the fence with technology, I should have ordered day 1.
Just flash to the SC BIOS, that's all I did. Cards are identical anyway.
For someone who hasn't ever flashed a gpu before, could you possibly post a link to a good guide or possibly even do a step-by-step "idiots guide" to doing this. Would be much appreciated buddy!
1. Get nvflash from the first post. http://bit.ly/1LYAntY
2. Get the BIOS (.rom). Save to the same dir.
3. cmd window:
Start, Run, cmd, right-click, Run as Administrator, go to the nvflash folder.
Shows cards in system with ID
nvflash --list
4. Device Manager:
Start, run, device manager
in Display adapters. right click/Disable all cards
5. cmd window:
To flash:
nvflash -6 GM200.rom
Where GM200 is whatever BIOS you're using. Index option to specify which card to flash, ie.
nvflash -6 --index=0 GM200.rom
You will have to confirm 'y' a few times.
6. Device Manager:
in Display adapters. right click/Enable all cards
7. Reboot, let the card get set up, reboot again.
From Overclock.net
Found a backplate from EVGA for the Titan X, not sure if it helps temps though.
"Helps to reduce heat by up to 3 degrees Celsius"
http://eu.evga.com/products/moreInfo.asp?pn=100-BP-2999-B9&family=Accessories - Hardware&uc=EUR
Perfect, cheers mate. See the step regarding disabling the display adapter - does this mean I have to boot and display via onboard graphics whilst doing this, or does disabling just mean disabling the drivers package whilst still able to output a display to monitor? Apologies if really dumb question.![]()
From Overclock.net
EVGA Hybrid comes with thermal paste already applied to the heatsink if anyone is interested.
Won't have time to install it tonight though as I'm off to watch Avengers: Age of Ultron.
