[RXP]Andy;27943191 said:Has anyone booked their car in for a oil service after the break in period?
As this is something I've been considering.
Always. You've only got to see the oil that comes out to justify that it's worthwhile. Typically £100 inc VAT if you supply your own oil to the OPC.
hmm maybe I should do that, they car is already on 3k miles.
[RXP]Andy;27943688 said:Wow. You have done a fair amount since March, mines only just hit 1300.
Hey guys, I've just stumbled across a Cayman and noticed the cheap price considering the type of car it is - is there something I am missing? Is servicing incredibly expensive? It seems a bit suspicious that such a car can be had for ~£15-£20k.
[RXP]Andy;27959122 said:They are pretty cheap to run really, the servicing as like most Porsches is 2Years or 20,000 miles which every comes soonest.
That sounds about correct money for a early example which may have high mileage or is a bit tatty.
They are epic little cars!![]()
What would you recommend in terms of warranty/servicing? Typical inspection cost etc? Finding it hard to Google for this info
Even the Boxters, e.g. 38k miles around £18k.
Had always imagined Porche to be really expensive, thus never looked.
So then......**** load more GT4's on there way to the UK
Now....R8 V10 or GT4....decisions decisions![]()
