- 9 Oct 2011
- UK
Also there is pretty bad backlight bleed in the bottom right.
It started so well with the sticker being on the monitor back to front, eesh.
Also there is pretty bad backlight bleed in the bottom right.![]()
At least you can send it back to OCUK and not Acer as its less than 14 days.
BTW the stuck pixel even though it disappears when you tap it you will probably find it comes back later worse.
Don't know what to do.
won't be tapping mine then anytime soon! I just tried GTA on this beast and it does the game justice it looks awesome. I would say though it's really hungry when it comes to GPU usage i've got 2 x 980s with everything maxed out x4 AA and FXAA on (bar the advanced graphics settings - all off) im hitting around 75fps using gsync on the beach - i think the forest areas will dip abit more - first time using Gsync too and i'm very impressed so far.
any form of stuttering at all?Run the pixel software on it over-night.
Is that software that comes with this particular monitor or something 3rd party than anyone can use?
Remember to set it to 120Hz in Desktop and set the preferred refresh rate option in 3D settings to "highest available" (so games run at 144Hz). NVIDIA drivers have a bug that forces the GPU to work at full clock when the display is at 144Hz.
you'll see!That won't fix the backlight bleed which is worse.
