So I've had some time to test my monitor and I have no dead pixels that I can see and some tolerable levels of back light bleed. There is some minor bleed in the top right and bottom left but I can't notice this in general use or gaming, the most notable bleed is in the bottom right corner, it is noticeable when driving around in GTA at night or viewing any content in a dark/black scene.
I have calibrated my monitor with an i1Pro to a 6500k colour temp, 120CDm2 luminance and 2.2 gamma, the screen brightness is at 20 in the OSD.
Photos taken in a "warmly" lit room with a Note 3 at 800ISO
Before this monitor I was using an Dell U2412M IPS 1920x1200 60Hz monitor, image wise this appears sharper and more clear, the colours seem to be more vivid even at the same measured calibrated levels as my Dell (Placebo?).
G-Sync is amazing, the smoothness is noticeable immediately I loaded up Diablo 3 first to try it and dashing around in my Monk was so fluid
, in GTA V I used to notice slow downs when moving towards heavy grass areas as the FPS would drop down to the 40's, now it's completely smooth in the 40's region.
Some things I noticed though, I used to use DSR/Dynamic Super Resolution for some games e.g. Diablo 3 which I'd run at 4k, with G-Sync enabled you can NOT use DSR, I don't see that advertised anywhere... but you can either have G-Sync on and no DSR or you can disable G-Sync and get DSR... don't understand this limitation I would have thought that those two technologies complimented each other.
The other thing I have noticed, which is bloody annoying, is my monitor refuses to save the settings when you power it off or restart the pc, I have to adjust the brightness and colour settings each time my computer is switched on or rebooted as they go back to defaults e.g. 100% brightness
Overall I think this is an amazing monitor, while I wish my panel was flawless and quite frankly I feel they should be at this bloody price, it's just the way things are at the moment with monitors, I've accepted this and the levels of bleed I have are tolerable for me, so I think I'll be keeping it.
