I got mine today. I was sceptical about this monitor after reading about all the problems people described in this thread. I only plugged it for few minutes but first impressions are positive. Build quality is really top notch, colors are better form my benq 2420t, not night and day, but better. Good thing is, I got monitor manufactured in December 2014 as Asus Rep suggests, these batch is revised and we should expect less problems with them. Strange thing though, I got euro power plug. I appreciate Haribo, but it would be nice to get converter or uk power plug at the first place
Now few questions
I changed default to this setting:
On mine I'm using
Brightness: 25
Contrast: 50
Colour Mode: User
Red: 99
Green: 98
Blue: 99
And gamma 0.90 in the nvidia control panel under adjust desktop colour settings.
Keep overdrive on normal
I found them a bit dark, so I switched brightness to 35.
This overdrive is OD in OSD menu, isn't it?
I do not get this Turbo Hot key. I press it on the monitor, it change nothing, I press on the monitor and press left mouse button, then it switch between Turbo 60,120,144hz. Under windows display settings, screen resolution, advanced, I always have 144hz, even if I select Turbo 60hz with Turbo hotkey.
I searched Asus website for the drivers for this screen but found nothing, is it me or we do not need special driver as windows 8.1 recognize this monitor anyway?
Hope one of you, more experienced user could shed some light in here
It is late, so I just want to try this G-SYNC Pendulum Demo and time for bed. Btw, I really like 1440p
