- 25 Nov 2011
- The KOP
It's not the OS that's the fault, it's the crap AMD are releasing that is! I'm not testing AMD's broken drivers!
It is the OS fault for Auto installing Driver! I guess is conflicting with other driver!
If the early build of Windows 10 had other options on installing updates you wouldn't have this issue you having..
You beta testing, report the bugs with Microsoft!
