- 11 Oct 2005
- Derbyshire
if it is up a tree, then a long pole, rope/string with something weighty on end? climb the tree?
Just noticed you're in Cardiff.. let me know if you want an extra pair of hands some time for the maiden..![]()
I will let you know when its properly patched up and i have gone over the surfaces again. I would say the place I fly although I could fly it there as it has space, its more suited to my multirotors really. Do you know any good spots which are public access, quiet and plenty of room ? Bouncy soft grass a bonus
Whereabouts in Cardiff do you usually fly you're quads?#
First immediate places that spring to mind are Pontcanna / Llandaff or Blackwier fields.
can't wait to go out again.
I need to try that programme a switch to give me Max elevator for takeoff
) and it was noticeably different with/without the switch.
Mine's set to just +25% up elevator, and makes it a lot easier I think, did some 'glides' prior to the initial take off to check general trim etc (obviously missed the elevator) and it was noticeably different with/without the switch.
Nice plane, and flying FL630![]()
Those toys were my pride and joy back in the day. The top one was electric, one of the first in the world of that size, 12S2P 10700mAh Lipo's, I think it topped out at 8.5KW power constant.Thanks chapsThose toys were my pride and joy back in the day. The top one was electric, one of the first in the world of that size, 12S2P 10700mAh Lipo's, I think it topped out at 8.5KW power constant.
I've just re-read your first flight report above, you shouldn't need too much back elevator to launch if you chuck it at the right speed. Max up elevator trim sounds like the CG is a little far forward, try moving the battery back a smidge it might help. It should, in theory, fly straight and level with elevator flat to the tail, if you've got loads of up then it's certainly a symptom of being nose heavy.
Also, try getting used to launching with your left arm and always into wind if you're not already, that way you're right on the elevator if needed without having to go and find the stick in the split second it heads to the ground
