I ran straight through a binary and stopped in between it and the main star, I mean I flew straight through it! how I survived I have no idea.
I've jumped into a lot of contact binary systems, but I've only once jumped right
through a star and yes, it's freaky!
I'm in a anaconda, should i turn around and save my exploration data or carry on regardless?
Your call, but bear these two things in mind:
- If you keep on exploring, it's only a matter of time until you jump into another system which could cause you damage
- As long as you act with presence of mind, there's no reason why you should ever take damage again
There are several keys to avoiding taking damage, the most important of which is to never initiate a jump and then leave your computer to do something else because as you have seen even if you set your throttle to zero there are systems where you will take damage as soon as you exit hyperspace.
The next key is to keep an eye on your temperature gauge in systems in which you know you've entered close to a contact binary, if it keeps rising then you have three options:
- Exit the area as quickly as possible in supercruise: this is the most instinctive option, and as long as you have a clear escape route then you will usually escape with no or minimal damage.
- Drop out of supercruise: this seems counter-intuitive, but should always reduce your temperature to below the point at which you take damage and allow you to calmly shut down non-essential systems whilst you plan your escape vector. Also allows you to deploy heat sinks if you have any.
- Save and exit: yes, you can "combat log" against stars; whilst I would never condone this behaviour against other players, I'm not going to lose dozens of hours of exploration data because of a freak stellar alignment. Once you log back in the game will place you a safe distance from the star and you will be safe to carry on.
n.b. I've only employed the last option once, when I jumped in between a neutron star and its companion white dwarf; a scary proposition made all the more so because the neutron star is all but invisible! I didn't want to gamble on avoiding the neutron star and getting trapped, so hit the save and exit button and when I logged back on was placed safely out of harm.
Follow the above steps, and there's no reason you should take any more damage as long as you're vigilant. Oh and not to be a jerk, but I did warn you about this a page or two back
