- 22 Jul 2004
Can you do 1440p + Fast AA?
Witcher 3 menu settings for Anti Aliasing is either 'on' or 'off'
And it's located in the 'Post Process' menu, not the graphics menu.
So I am assuming it's FXAA or SMAA only?
But I'd say 1440p with no AA is better.
No problem
I updated my original post with these instructions too. Don't think it's worth a separate thread but if OP wants to add, the post link is below.
http://forums.overclockers.co.uk/showpost.php?p=28056884&postcount=2236
Nice, my 970 arrives tomorrow & have a 2500k @ 4.3GHz, 16gb Ram, SSD for game & 1080p so should be getting very similar performance.i7 2600k @ 4.2GHz
16GB DDR3 Ram
970 at 1450MHz
1080p
Every setting on ULTRA/highest I get 30ish fps in cutscenes and 40-50 in game.
.Nice, my 970 arrives tomorrow & have a 2500k @ 4.3GHz, 16gb Ram, SSD for game & 1080p so should be getting very similar performance.
If it drops down too much I may just get another 970.
I'm not a fan of SLI plus the Vram issue is preventing me from seeing it as a long term solution, I want to get a 4k monitor once a suitable one comes along.Hairworks... I don't know what the big deal is about it, doesn't look that good with it on?? I'll try it off later see if i can notice any difference.
Why is hairworks so damn graphics intensive!!! takes my fps down from 60-70 to 40-55![]()
Ok since enough people are having trouble with installing my profile here's a mini installation guide.
1. Go to www.reshade.me and download the Reshade + Sweetfx 2.0 pack
2. Unzip and copy the sweetfx folder, reshade64.dll, reshade.fx and sweetfx.fx files to the witcher exe directory in The Witcher 3 Wild Hunt\bin\x64
3. Rename reshade64.dll to dxgi.dll
4. Delete SweetFX_Settings file in the sweetfx folder.
5. Download my settings here http://sfx.thelazy.net/games/preset/3696/
6. Rename the settings file to SweetFX_Settings and copy it into the sweetfx folder in the game directory.
Currently the toggle function isn't working but should be fixed in the next reshade update.
