- 2 Dec 2009
- barrow in furness cumbria
Ahhh yer, if you get stuck, I can live stream how to do it?
thanks dude
thanks dude![]()
Search for 2560x1600 benchmarks and take off 15-20%. Should give a rough idea![]()
Yep, have been looking around, they seem to vary so much from source to source. Seems I should be okay with reasonably high settings. Have an itch to buy a second but only came to the site to buy cable combs initially and now leave with a Titan
Greg and his Vid's![]()
ur a star dudeHey, I need the practice if I want to be good one day
Uploading now Gaz![]()
ur a star dude
i need practice too..got a gopro4 black couple of months back and harldy used it...need to watch some vegas tutorial videos first![]()
I have a gigabyte titan x. Really tempted to buy another titan x what with the Ocuk model at £800. Is it ok to run two different brands in sli?
Your penis must be huuuuuuuuge.
Obviously a nice rig but.....all that to play on medium? I am disappointMy first ever youtube video.
Battlefield Hardline in 7680 x 1440.
Settings are on medium
Here is the system spec
Asus Rampage V Extreme Intel X99 (Socket 2011) DDR4 EATX Motherboard
Intel 5960X Extreme 3.00GHz (Haswell-E) Socket LGA2011-V3 Processor clocked at 4 Ghz
Corsair Hydro H105 240mm Extreme Performance Liquid CPU Cooler
Corsair Dominator Platinum 16GB (4x4GB) DDR4 PC4-21300C15 2666MHz
3 x GeForce Titan X 12288MB GDDR5 PCI-Express Graphics Card SC Bios
3 x EK Water Blocks EK-FC Titan X - Acetal+Nickel
3 x EK Water Blocks EK-FC Titan X Backplate - Black
2 x EK CoolStream RAD XTX (360)
EK Water Blocks EK-FC Terminal TRIPLE Parallel
EK Water Blocks EK-D5 Vario X-RES 140 (incl. pump)
Soundblaster OMNI DAC
Samsung XP941 M.2 PCIe SSD Boot drive
Enermax Platimax 1500w '80 Plus Platinum' Modular Power Supply
10 x Corsair AF120 Quiet Edition Low Noise High Airflow
Corsair AF140 Quiet Series Low Noise High Airflow
DEMCiflex Dust Filters
Case Labs Mercury S8 Black case
3 x Asus PG278Q ROG Swift 27" G-Sync 144Hz in surround
Logitech G400s Gaming Mouse
Logitech G910 Gaming Keyboard
Sennheiser PC360 Headset
