The GTX Titan X owners thread.
Search for 2560x1600 benchmarks and take off 15-20%. Should give a rough idea ;)
:) Yep, have been looking around, they seem to vary so much from source to source. Seems I should be okay with reasonably high settings. Have an itch to buy a second but only came to the site to buy cable combs initially and now leave with a Titan :rolleyes:
On a side note, is there any difference with the EVGA SC BIOS that allows you to get a higher overclock or is it literally just higher out the box settings being higher. Will put the card under water but cant tell if flashing the OCUK variants BIOS may help achieve higher overclocks?
My first ever youtube video.
Battlefield Hardline in 7680 x 1440.
Settings are on medium
Here is the system spec
Asus Rampage V Extreme Intel X99 (Socket 2011) DDR4 EATX Motherboard
Intel 5960X Extreme 3.00GHz (Haswell-E) Socket LGA2011-V3 Processor clocked at 4 Ghz
Corsair Hydro H105 240mm Extreme Performance Liquid CPU Cooler
Corsair Dominator Platinum 16GB (4x4GB) DDR4 PC4-21300C15 2666MHz
3 x GeForce Titan X 12288MB GDDR5 PCI-Express Graphics Card SC Bios
3 x EK Water Blocks EK-FC Titan X - Acetal+Nickel
3 x EK Water Blocks EK-FC Titan X Backplate - Black
2 x EK CoolStream RAD XTX (360)
EK Water Blocks EK-FC Terminal TRIPLE Parallel
EK Water Blocks EK-D5 Vario X-RES 140 (incl. pump)
Soundblaster OMNI DAC
Samsung XP941 M.2 PCIe SSD Boot drive
Enermax Platimax 1500w '80 Plus Platinum' Modular Power Supply
10 x Corsair AF120 Quiet Edition Low Noise High Airflow
Corsair AF140 Quiet Series Low Noise High Airflow
DEMCiflex Dust Filters
Case Labs Mercury S8 Black case
3 x Asus PG278Q ROG Swift 27" G-Sync 144Hz in surround
Logitech G400s Gaming Mouse
Logitech G910 Gaming Keyboard
Sennheiser PC360 Headset
Obviously a nice rig but.....all that to play on medium? I am disappoint
That setup should eat Hardline alive even at 7680x1440, Crank the settings up.
If anyone posts videos for the user video section in the OP could they mark them User Video please.:)
Please give details -
The subject,
How many TXs,
CPU,
Clockspeeds,
Drivers,
Resolution used.
It hath arrived ! :D
Got an extra 3 years warranty for free on this too through Zotac, 5 years total, Not bad at all :)
