- 7 Jul 2009
- Newcastle/Aberdeen
I like the dropped seatstays, but the top tube is way too sloped for my liking. Prefer the Merida/Ridley/BMC bikes set up like that.
Wow its windy out there tonight....
If you do go for those, let me know how you get on.
My brother bought them... Wouldn't buy again tbhget some "bolle" glasses from eBay! On my 3rd pair now and they're great.
Mechanical discs tho :/ Have to go hydraulics on my next bike, which brings me on nicely.
I recently had a surprise inheritance, and I've decided to use some of the money to change my road bike. It's a little too small for me, and the geometry doesn't really suit me for longer rides. It's the perfect size for a work colleague, so I'm hoping to recoup some it's cost.
Personally, I really like FT's custom build, a carbon road bike with hydraulic discs at a reasonable price. However, I wouldn't have a clue which frame to buy, and I don't have the skills to build it. I'm not sure how much it would cost to get someone else to build, or whether that's feasible.
So, I wondered what bike you guys might recommend I take a look at. Ideally, like to spend between £1,500 - £3,000 max. I'm coming from a Planet-X Pro Carbon.
Thanks![]()
It's supposed to settle down in a bit - good job as I'm planning to go out for a couple of hours. I just have to make sure I'm back before the rain! You can't win, it seems...
Torgue setting do I need for a MTB and a road bike cassette?
Having them both off this weekend.
It should tell you on the locking ring.
Annoyingly the rain came early for us - got caught out between Alderley and Ashley and god soaked. And now I'm home it's sunshine again, gah!
