R9 290X Owners Thread
I have a D2X alongside my 290X and it is the one thing that is stopping me considering Crossfire due to the location of the PCI slot it uses on my mainboard. DD Live is very important to me as I output to my Denon AV Receiver. As yet I am unaware of another way to get full DD5.1 via another method for gaming; sound down HDMI from a graphics card doesn't do this does it?
Anyway back to the point; here are my settings. I am currently outputting via DVI-D so all of the sound card settings for the HDMI show disconnected not sure what would happen if I used HDMI instead. Either way these should override. Setting the games into Surround/Home Cinema/5.1 whatever then works fine for me and my amp always shows Dolby Digital input.
Hope that helps :)
Thanks loads for your reply, I'm actually using a Denon receiver as well, the AVR-1911, so it looks like we might have similar setups, but have them wired up differently. I tried your settings but I still hear no sound, although I can see sound is being output. I'd attach screenshots that hopefully show what I mean but I don't know how. How did you attach yours? And is it possible to hide images in spoiler tags?
OK, so to expand a bit on my setup. Originally I connected my 290X's (in crossfire) to the VGA input on my Samsung display. This of course meant I got no sound, so I connected my D2X directly to my display, out from the green lit connection, (front out I think it's called) and into the 'PC/DVI audio in' connector on my display. I used what is essentially a 2 male ended headphone cable, if that makes any sense, to do this.
So I was able to get sound from my sound card that way, but only in stereo, not 5.1 like you mentioned.
I also had a lot of display problems when I connected my 290X into the old VGA slot, so had to switch to HDMI. My 290Xs now run smoothly and with no problems, also doubling as my sound source as well now. Unfortunately this means that I'm not outputting sound from my D2X which, like you, is what I'd prefer.
So my PC is connected directly to my display via HDMI from my 290X and the cable from my sound card. My display in turn is connected to the 'Monitor Out Arc' HDMI connection on my Denon AMP with another HDMI cable.
If I've understood what you've said correctly, then your 290X is connected directly to your display using a DVI-D cable and your D2X is connected directly to your Denon AMP? What cable are you using to connect your D2X to the AMP and into which input?
Hopefully what I've written makes sense.
Thanks again :)
I'd really like to try crossfire out sometime, I guess I'm just gonna have to wait and see what AMD's new stuff is like before I decide if I want to crossfire my 290x or not :)
When crossfire is working it works amazingly. Better than a titan x and about half he price.
They're in the cupboard at the moment, back on the 295x2's at the moment.
Ahhh. Im trying to break 20k atm with firestrike but cant get the cpu above 4.8ghz.
Managed to get my 290's to 1200core 1600memory +100mva but need more power to get it any highers.
Currently got 19,300 score.
I've not benched for a while, but no doubt that will be changing in the not too distant future.
yeah I suppose it can be a headache at times, but at least how I see it that sort of thing happens a lot when building pcs anyway, so some annoyance is inevitable in my experience :) right now my backup is to get a new psu and a 295x2 and watercool my system after that (gonna do this eventually anyway)
Hi I' not sure on the specifics of the problem you're having but in general yes the audio output from the graphics card should be capable of output multi-channel surround via HDMI. On my HTPC I use an AMD Kabini apu and have the HDMI output connected directly to my AV Receiver (Pioneer VXS-922) which then in turn connects to my TV via HDMI. Over that connection I can output up to 7.1 surround in pcm bitstream format or full DD, DTS, DD True HD etc. I use it for playing blu-ray rips and get the full audio tracks fine.
At least I have to wait to be able to upgrade anyway, so hopefully AMD's new cards will be out by the monday after e3/Evo because that's when I get paid :p
I really should upgrade my psu whilst I am at it too...
