- 10 Nov 2012
- Down the road from Diddly Squat Farm
LMFAO
Don't want to ask what you think of the AMD owner threads![]()
LMFAO
Ive not installed afterburner or anything like that but looking at GPU-z my idle temp is 62 degrees with a fan speed of 24%. Is that too high?
Also it says performance is capped?
I'm sure pink is temperature.
Check what temps are when that bar goes pink.
Playing Witcher 3 maxed and its running nicely (alt tabbed so the clocks obvs dropped) but the pink bar with the blue section is a bit baffling?
Absolutely chuffed to bits with it though. Its a thing of beauty and I cant wait to start playing the games my lowly 780 struggled with![]()
Witcher 3 with latest updates and Titan X is absolutely awesome.
Was a bit disappointed with W3 performance at first but with the optimisation and latest patches it's blinding on the PC. CDPR do work hard to get things right.
