Do you have any trouble with the chain eventually moving forward into your back? I put my US-10 on for a trip the other day and the chain slid forward slightly into my back making it very uncomfortable
. 8KG or whatever it is of chain pressing into your back for a couple of hours isn't great.
Not sure how to sort it really, unless I put something between my back and the tail pack, or something inside the pack at the bottom. The Speed Triple pillion seat is tiny.
Love the idea of it though. I managed to attach the straps under my seat so I can tuck them inside when not in use so you would never know it can take a tail pack.
/QUOTE]
i set the straps up on the sub frame so there was something infront of them (grab handles for rear, and for the front to where the some frame has bracket welded.) so they cant slide forward, pull pack on rtight and it stays secure and far enough back.
Oh, also one of the hooks came undone on my way back from Hereford, only realised when I got home. That could have been a disaster. Not sure if I'm not doing the thing tight enough or what.[
you are not doing it tight enough
each pair (frpont and back) hold both and pull them out to the side/down to tighten them against each other as much as possible (be firm you aint gonna breakanything) theywil lgo much tighter that way, then snug up the loose webbing with thw clips .
or the other option turn the pack sideways.
