I added the fan I mentioned in my previous post to create a push pull and decided to just install the radiator at the back of my case after realising how much heat it outputs. Temps improved by 3C. After 15 minutes of crysis 3 gpu 1 was max 71c and gpu 2 was max 69c. From all the stuff I tried so far that game seems to heat up the 295x2 the most so far.
I noticed gpu 1 dropping from 1018mhz to 9xx at times. Is this the throttling? The 2nd gpu stays locked on 1018mhz.
What games or benchmarks do you guys use to test how hot the card gets? I am not too bother about the heat as it will be coming out the back of my case, but I would rather the gpu not throttle, as that may cause noticeable fluctuations while gaming.
Any tips are welcome
