You guys that have Watercooled this, have you felt the need to keep the bottom fans in? What would they even cool if you've got a block on the GPU and CPU?
I owned one of these for 18 months and while being a very decent case I did feel the cable management couldve been better myself. It is however a very quiest case with brilliant air cooling, but very heavy and i found difficult to get the side panels on and off.
Contacted silverstone about replacements, should be interesting to see how much these cost.
. Hopefully to be used again when i go back to air cooling on my next build, whenever that is. It is without a doubt the best case i have ever owned.
Three years later and it looks as clean inside as the day I received it.
The 90 degree rotation is great for heavy cards.
The cable management is a bit of a pain alright but it had just about enough room.
How did your case fall Gerard?
It is STILL the best case available on the market, imo. Quality is absolutely top notch. I've had mine 4 years, and when I get a new machine I'll get another one unless Silverstone release something better.
Nothing else compares.
.Im still running my Silverstone FT02-WRI which I had since 2010 , prior to that I had a Silverstone TJ-04 with Side Window Mod.
However I will be shortly be changing cases to a Fractal R5 in White as soon as a supplier gets them in stock.
Guess it is time to move on from Silverstone cases as nothing on their current range appeals to me at all.
why change ? any other case is a downgrade
