Thanks Bru and that I can read![]()
I cannot really take the credit all I did was crop the original.
from here.
This very thread, post 6756
Edit: Which I see he is now using the cropped images I hosted in the first two spoilers.
Omg we are at the "amd needs to be twice as fast for half the price, with 5AAA games, and maybe i consider getting one" phase again...
I agree with this. If the performance is there then AMD have a right to charge for it. I think if AMD really want to win back market share their cards have to be significantly better i.e. 20%+ faster than Nvidia's, albeit at a competitive price that doesn't sell themselves short.
However, I don't think they should exceed the pricing of the Titan X since Nvidia themselves have made it irrelevant with the 980Ti. 100-200 pounds below the Titan should be fine if it is significantly faster.
From my experience, AMD's single gpu drivers are pretty good, I never had a TDR with them while I've had quite a few with NVidia's (ironically the latest drivers are perfectly stable for me). Although Nvidia's multi-gpu support has been far superior (compared to AMD 4870X2).
With the advent of the next generation APIs, these constant driver releases will hopefully be unnecessary and a thing of the past anyway as it will be the game developer's job and drivers will be released for bug fixes only.
Basically, I hope these cards give Nvidia a well-deserved kick in the backside so that they're not able to release a ludicrously expensive TitanX and then a month later release a card that's just as fast for half the price.
It's a miracle of marketing that they are able to get away with this, particularly since Titan X doesn't have the Double Precision compute power of previous Titans.
Mmmmmm
Surely the only way is two compare the exact same card, HBM versus GDDR5, which is impossible?
Synthetic benchmarks will obviously show a gain for HBM memory, in say the bandwidth it can give etc, but I'm not sure how we can gauge how that's helping a game.
Run the card around the Heaven 4 bench and underclock the memory until it takes a performance hit.
If HBM is as good as we keep getting told even a 30% or 40% underclock on the memory will make no difference.
AMD Fiji X 'Nano' £699 VS Titan X £850+
AMD Fiji X £649 VS Titan X £850+
AMD Fiji Pro £499 VS 980 Ti £550+
AMD 390X 8GB £349 VS 980 £389+
AMD 390 8GB £249 VS 970 £249+
My guess is something like that.
And the consumer ends up worse off with these higher tier of pricing.
AMD R9 R380 and R390 have respun chips
Improved Hawaii and Tonga launch on the 18th
http://www.fudzilla.com/news/graphics/37967-amd-r9-r380-and-r390-have-respun-chips
Should we be worried that they cropped the image so we cannot see the other end of the radiator ?
It shouldn't be a 240mm one as the 295x2 only needed a 120, but interesting that they cropped it that way.
Greg you getting old..time to change for a bigger display..
It would be good if AMD actually forced lower tier pricing and made enough money for profits and R&D, but its not working, at all.
for the good of all involved i would rather AMD charged a bit more so they can exists and even have some income.
You can see it's only 120mm.
Eh, would you care to elaborate, the end of the rad is missing it has been cropped so you cannot see the end of the radiator or the end of the fan.
Or do I need to go to specsavers.
Don't get me wrong I do suspect that it is only 120mm, but that image definitely does not confirm that.
I don't want bargain basement GPU's.
But this 800-900 quid single GPU lark is... Well, less said of my opinion about it the better.
A lot of AMD's stuff not working out is due to inferiority, priced as it belongs, things will sell.
AMD could have a Titan X clone (Or every other Nvidia GPU), it'll never sell as well at the same price point (Because of everything else).
I'm not in the market for a GPU over £500, but then I never have, and I've owned a ton of launch day flag ships.
All I want is a card to replace my 290X, at the same price point that a 290X launched for, with 40% gain. After 18 months, something that doesn't fit those requirements is a fail for me.
