I'm using 1 and 3, pretty sure that's what the manual said.
Another user video for you Kaap.
The Unreal Kite demo, Ran at 1080P using the target line command.
CPU: 4790K @ 4.80GHZ
GPU: Titan X @ 1400/8000
Driver: 353.12
X99A XPower and you're right, just had a look.
I seem to remember 8pack saying that Asic has little or no effect on these cards as far as clocking goes, but I could be wrong. Mine is 77.7 and clocks well.YMMV.
I wouldnt worry too much, there's next to nothing in it from x16x8 to x16x16
i have been watching and reading some reviews . i wonder why some reviews at 4k, the stock 980ti are exactly the same fps as stock Titan. or some are even 1-2fps faster . ( most of review Titan X are still faster 1-2 fps )
what am i missing here ? because i want to upgrade to Titan X now from 980ti ( waiting to be in stock ) but if it won't be a little faster then it is no point to upgrade.
l o l
I doubt they are running on the same boost (luck of draw). Clock vs clock the TX is faster.
Mine are rocking 1424/2000 on air (stock bios) the equivalent overclocking on a GTX980Ti will be slower.
Edit: It won't be noticeable though moving from a GTX980Ti to a TX unless you are using settings that go over 6GB VRAM.
