- 27 Jan 2009
- Oxfordshire
Haha that's amazing!
Use the old bearings as a drift to knock the new ones in. Guaranteed to be exactly the right size to fit with the new ones.
how are you finding them?I want to pick another set.. but it's just too cheap for my bike haha
Also have a hole in 1 of my good pairs of shorts - the velcro from my saddlebag came slightly undone and has snagged the inside ride leg. It's not stitch-able, but are there adhesive lycra 'patches' you can get?![]()
do any of you run powermeters on your bikes?
just been given a surprise work bonus so was thinking of getting onethoughts so far
stages cost a lot in the UK as they only come on new crank arms, currently have had battery issues and only left side power - £570
P2M type s: decent value and seems really solid, can fit to my current cranks - £700
garmin vector - 2 pedals is a really crazy amount so the S type will again be only left sided. They also look a bit fragile compared to the rotor PM's
4iiii - think they are still factory install only with crank getting posted to the states - $400 + postage etc
Has anyone tried one of these heart rate straps that calculate power from the rate of change of heart rate? Can be had for £50-100 and supposedly are surprisingly accurate. Could be a good stepping stone?
Some people
As a cyclist I am not happy with the rise of camera totting road lawyers. They need to leave policing to the police.
