- 28 May 2007
It looks amazing but they need to sort their drivers out.
As do Nvidia.
+1
So much rage..
As do Nvidia.
Forgive me, but I can't keep up with all the hysteria.....Is "the fastest" card in fact just a dual X2 type with 2 'chips' on one pcb, right? So apart from being small and cute, it basically means that like all other X2 cards in history it's essentially crossfire, and will therefore rely on crossfire profiles for all new games and decent driver support?
Good luck with that....
.Honestly... Drivers are fine.. Couple crossfire profiles needed sure but the drivers are perfectly fine..
At the moment nvidia are having much more problems with black screen driver crashing, some users reporting sli stuttering even with Gsync..
Not defending amd here I agree crossfire needs some more work on getting games working.. Mind you it is only the odd couple.
But let's not pretend nvidia is Mr driver perfect..
They both need work and at the moment I would rather play then crash.
Am I missing something ?
Single Fury X = 2 X 8 Pin power connectors
Dual Fury X = 2 X 8 Pin power connectors![]()
I wonder if the 390X will end up faster than the Nano? Although the Nano will be more expensive (maybe 500$?) due to the small form factor...
They said the Nano will be faster than the 390X in the presentation.
LMAO
Did they? They said a lot of contradictory things, tbh...
LMAO
