The Witcher 3: Wild Hunt
Turns out GeForce Experience has been setting my Texture Quality to Low instead of High but reporting it to be set to High, up to Ultra it goes.
I thought the game looked a bit bad tbh.
makes me sad I completed this lol. Just spent an hour wandering around the world and its so beautiful. I could play this for another 100 hours if there was more content as the world is just so fun to wander around in.
Have you done all the ?'s dotted about the place? Or have you mostly focused on the main quest only?
I just bought Greater Glyph Of Igni crafting guide, but I can't find it in my inventory to read and I can't craft it.
Where does it go or how do I use it?
As soon as you buy any recipe you auto learn it. To craft glyphs you need a blacksmith.
As already mentioned, glyph manuscripts are found in the crafting menu and requires a blacksmith. There are 3 manuscripts, lesser, glyph and greater. You can use the glyphs you have crafted to upgrade to the next level, lesser>glyph>greater, but you can't use glyphs that you have found.
I bought most of these at Crows Perch and a few I found.
Cheers.
Since upgrading to the Asder00 driver for 15.5 from Guru3D, my game doesn't load up a saved game now. I just get a black screen when it tries to load in, and nothing else happens :(
Have you tried downloading the driver from AMD? I'm using the 14.12 driver and not having any problems. Never use Beta drivers personally.
I was using the AMD 15.5 beta before and it was fine, but Asder00's drivers are optimised for newer games, so I thought I'd try that given how poorly the CrossFire performance in The Witcher 3 has been and that AMD and CD Projekt Red haven't made any inroads into fixing it yet.
Just got to Ardvik to get the Anvil in the Armourer quest, killed the Troll, now all I do is jump about. Can't even access any of the menus. Anyone else experienced this.
:mad:
Just had my first infinite load/hard lock crash since installing the game! Currently at level 18+, just been playing for about 8 hours and I loaded up a save and it just kept on loading and loading and loading. Couldn't get out of it, did a ctrl alt del, hard lock.
