Greg, what was the name of the capture card you used on the Fury X? Did it work okay, any issues?
Avermedia LGP Lite. No performance hit but sadly only records 1080P 30 fps
I am now encoding PCars from the TX and FuryX. Any other games people want to see?
That's a shame, as I wanted to compare at 1440P![]()
GTA 5. Can you not run AB to show temps, gpu usage and the rest.
we need totally uncompressed screen-grabs and videos to make true comparisons.
GTA V it is. Leave it with me and I will record that and AB shows up, so no problems seeing what is what. Work at 2pm, so will need to be done tonight as well.
The video is perfectly fine to pull up rendering issues as both halves were recorded at the same quality and with the same capture device.
Here is what i am talking about which you keep ignoring or just don not see.
It is a texture filtering issue on the TX. Either there is an issue with BF4 and nvidia drivers or Nvidia are purposely fiddling LOD to boost performance.
Which needs communicating & the product lines in question recalled for fixing, not leaving the consumer to play Fury X lottery & hoping they don't get a turkey.The pump whine was fixed with shipping variants. But some of the faulty version that were sent to reviewers were also sent out to the general populous.
If you look a page or two back you can find how to tell the difference. Someone posted a picture showing which are the newer/fixed model of pump.
Mine is being collected today by a competitor.Has it been confirmed whether or not retailers are taking returns. I seem to recall someone earlier in the thread had a problem with returning his due to the whine. I hope it gets sorted eventually as i agree you shouldn't have to play a lottery.
Greg, have gpu usage showing in pcars please.
Yer, I have done
Oddly, the VRAM usage on the Fury is half of what it is on the TX.... Any idea's? Memory compression perhaps?
Really annoys me when people say nvidia cards overclock "so much better" than AMD cards, then quote the base clock to final overclocked boost clock comparison and say like "oh my god 50% overclock" Lmfao... idiots... you need to compare out of the box observed boost clock (not just what it is advertised as) with fully overclocked boost clock to see how much you are really overclocking. Hawaii isn't an amazing overclocker by any means, maxwell is better yeah, but its hardly an insanely large amount of difference, usually the MHz gain is around the same, which funnily enough, is an advantage for AMD, since each Hz gives more performance in hawaii than maxwell.
With voltage unlocking I am hoping this will be able to get pretty high. I mean I can get 1200 out of my r9 290 with 120mv, GCN 1.2 overclocks better than 1.1, so I am hoping 1300 with 200mv. 24% overclock isn't bad imo, very similar to reference 980Ti overclocking (although it does need more volts to get there... 200mv compared to 50mv).
