DP needs his eyes testing thenit's very clear to see what GPU is outputting a more higher detailed images..
It's night and day difference.. But what I do know is messing with LOD does show quite massive gains in frame rate.
Making a more detailed image does not necessarily require increased load, e.g. look at Antialiasing, the higher the level the less detail there is.
Anyway, all of this is a complete red herring as gregster didn't have the same video capture properties on the same cards.
You should compare screen shots, there is really nothing in it, unless you are a fanboy.
Greg did have the same settings used he redone the video using 30mbs, same capture hardware, same hardware only change was the GPUs and drivers..
I have asked for images, and even in another thread another user has agreed his 780 shows same level of detail so something is clearly wrong with battlefield 4 on nvidia hardware..
Instead taking it so hard maybe back this and see if nvidia can fix it.. Who knows might just be a game bug or worst nvidia is indeed reducing graphics settings to look better. I would like to believe this isn't the case,but ask yourself based on that screenshot side by side would you pick the extra frame rate over the IQ?
Truthfully, at the moment with the current drivers, the performance at 1440P-144hz is a ...Meh... Don't get me wrong the card is fast and I'm hoping that with unlocked voltage will come the "Overclocking beast" that we were promised or else AMD were talking out of the ass.
The card however (At least mine) is cool, quiet, well built and looks great, hopefully we'll get new drivers soon and unlocked voltage which add to it.
As it stands, if it doesn't improve, i'll either grab another when their in stock or move back to the Green team.
I can't believe people are still arguing about this based on the same low quality video. It's been cut up and edited together, compressed and then captured in a pause frame with all sorts of blur going on and blown up. It is completely useless. You also have no idea of the settings of each card.
As i said before i'm certainly no expert but it is so obvious that you cannot make a fair comparison.
Absolutely ridiculous the nonesense some fanboys will try to parse off.
Don't make a fool of yourself, Shanks
I think they are holding the drivers back again, until Win 10 releases this time, so be the end of this month.
I barely looked at the image before, just gone back and had a good look. PMSL, how insane must some people be if they are really basing hose youtube captures as any kind of comparison.
The whole thing is destroyed by horrendous video compression and blurring.
lets see static side by side screen shot, no video malarkey at all.
I dont think he's running ultra settings on the TX.
Watch the vid he's clicking no to save settings.
As D.P and others keep ignoring. The cards ran at the same in game settings with the drivers left at stock.
Both plays were recorded with the same hardware at the same settings.
If compression artifacts and youtube reencoding were going to effect the image quality then it would effect BOTH halves of the video equally. Not 'Oh lets blur and reduce the quality of the TX side more. All while making it appear that the TX is not rendering at the same LOD.'
It shows in the video and not just the still. The character runs at the same speed in both videos and greg is not erratically moving the camera around on either. So in game blur is not the cause.
Tell you what, Lets settle this. Someone with a fury X and a Ti take a screen shot roughly at the same location. It will then be obvious? No video compression, nothing and plain for all to see.
