Timely is absolutely brilliant.Is anyone using any different alarm clock? Not finding the default one pleasurable or customisable at all
S6 is now down to £420 on amazon UK.
install this: https://play.google.com/store/apps/details?id=org.vndnguyen.phoneinfo
it will tell you the country code your phone is set too
look for "Active CSC Code"
let us know what it is
@Quinnaay I notice the huge drain from your phone radio which might mean you are in a very weak signal area, an app is using your radio a lot or you have a broken radio/antenna, obviously somethings not right.
I bought my phone from a german store on ebay (a highly rated one). It was brand new. For some reason, I kinda blame the battery woes I'm having on the fact that it was from germany. I don't know whether there is some modem incompatibility or something. Anyway, it's probably just me being crazy, but thought I'd let you know anyway.I bought my S6 off ebay and it's unlocked but it's a European sim phone only.. Maybe that's why.
Gave the phone abit of a hammering this morning and having to charge after 6 hours of it being unplugged is a joke and made my S5 look awesome. Not sure what to do.. As for the held awake I can't click that to see what hwt it is.
Not sure I'm going to be lasting with this.. Another 7.5hrs and I'm at 4%battery.. Not acceptable.
Return it for another? Maybe it's faulty.
