well, it's sideways for one and that'd be difficult to fit on my head ha
now to measure my melon
So yeah, it's a bargain, but it's not the Di2 you're thinking of.
120 psi James? Are you on 21mm tyres or something?![]()
Had a low speed collision with a van last night - not really the driver's fault as he had to emergency stop for someone randomly pulling out and it happened to be not long after a small descent...and I misjudged my brakes. Fun times.
Well, you just need to give those other poor TTers a chance, right?![]()
Ugggh....finding it hard to get motivated to get out of bed in the morning and ride to work. Managed it today but have been totally useless these last couple of weeks.
Need to get my mojo back.
been trying to trace down a creak/click in my bottom bracket area for a few weeks now, had it all apart a couple of times, cleaned, greased, chased, faced, you name it.
rode the bike up and down my street in trainers to test some other stuff last night.... no creaks or clicks
this morning I sprayed some GT85 on my cleats and on the pedals, rode to work. Perfect.
gahhhhhh
Always the simplest things...
I have a click that comes and goes on my bike at the moment. I thought it was the saddle as it stops when I stand up, but I've cleaned and greased the saddle rails and it's still there. I might try taking the seatpost out next and see whether that needs cleaning. I don't think it's drivetrain related as it comes and goes and it's not a regular thing like once per turn of the pedals or turn of the wheels. It's driving me nuts. I might replace the BB sometime soon, see if that fixes it.
Just a heads up - last time I sprayed my cleats and pedals with GT85 I lost a cleat bolt the next big ride...
Must get into the drops more too - it is so much faster. It's odd - I don't feel uncomfortable down there in terms of aches etc but I just naturally want to move back to the hoods. Muscle memory I guess and the solution is probably just simple ride more in the drops.
Try not to get it near the pedal bearings either, it'll break down the grease in them.
'chased', 'faced'?
