New card just turned up - hopefully minus the coil whine..
I would definitely recommend people put these under a waterblock
How much does it cost to watercool a whole PC? I was looking at it but I was told it's close to £500 which I don't particularly want to spend![]()
I would definitely recommend people put these under a waterblock and do some BIOS modding to get rid of all the clockspeed fluctuations etc, this is what I have so far...
It clocks so well the line has turned yellow.![]()
That's what I'm afraid of... I'll stick with air for the time being - I get reasonable temps!
Most of all, the Amp! Extreme has a beautiful "unique" backplate:
** No hotlinked images please **
Amiga what waterblock did you buy for your 980Ti please?![]()
I too am able to get my MSI 980 over 1500. Why is 1500 the hard coded limit in the graph for both msi afterburner end evga precision ?!
I just use £1.20 1/2" barbs with 7/16" ID tubing, if you dip the end of the tubing in some boiled water and then push it on it'll never fall off, in fact it takes a lot of effort just to pull it off yourself. If you go with fancy compression fittings and stuff it can soon mount up.
Or go AIO, much cheaper.
I'm considering going 980 SLI later this year as I already have a 980 EVGA, how would that rate against the 980 ti and Titan?
