- 11 Sep 2014
- Suffolk, England
So the time has come! Molten Gold has its new update at last. It's a mix between big & small. Big in terms aesthetics, but small in terms of work done overall. Anyway, on with the show! I got myself a riser cable & decided if I couldn't get a full cover water block and back plate to make the gpu look decent, then it's only right that I show off the windforce cooling! So here it is, I give you, my sideways mounted gpu!
Ideally, I would love to be able to plastidip the blue, green and grey parts to the riser to a black finish, but I don't know if that's possible/safe to do so? Anyone able to help me on that one?
Rushed attempt at removing the gpu bracket braces, used a small drill bit to eat away until it could be snapped off. These bits will eventually get filed down & resprayed.
Overall, I'm quite pleased with it. Just gotta tidy it up & it's good!
Nice build
