Proximity mine outside a Los Santos garage is always a good one....
Did you redo the adaptive vsync in nvidia panel and disable vsync ingame to fix the micro stutter? Its a well known fix. If you have done it then nvm. Could be a driver version instead.
The R* intro movie gets screen tearing on it, so I used that to test the setting in nvidia control panel. Turns out having Adaptive Vsync on in the control panel was causing it.
I'll see if it's solved the issue in game too. If so its the oposite to what you were suggesting which feels odd?
Edit: Nope, its made no difference. The micro stuttering and flicker on overlays is still there. The tearing when browsing the world map is gone however.
Edit 2: I turned off everything I had set in the nVidia control panel and there is still stutter and flicker. Im going to try dropping back to the nVidia GTA5 drivers.
Edit 3: Still no difference with the game ready drivers, so its something in the game itself.
For those with the D3D INIT error, go to my documents>rockstar games>gta 5>settings (open with a text editor) look for "dx" in the search, replace the 1 or 2 with 0 and save.
I struggled getting online, constant unable to connect then when I did... failed to connect to you guys on a different server.For some reason I started crashing last night, rarely ever crash and crashed 5 or 6 times last night, I hope this isn't a permanent thing.
No, he has an AMD crossfire setup (well AMD card for sure).Nvidia 900 series cards?
Ok just tried a deathmatch... ass handed to me.
I don't get it. They just hit me once and Im dead.
Yet I pile bullets into them and nothing....
More rank? More Damage?
2x 290. It's not the failed initialization error, it just says that GTA is not responding.Nvidia 900 series cards?
