Fixed![]()
how is that fixed? you got 3x 2gb?
Fixed![]()
Yup. But it will down clock 13 mhz at roughly 67. Then another 13 at 78 people say.
I've not seen my temps above 75 yet. Lots are sighting thus "feature".
You not noticed it setter? Maybe not all cards are equal but my googling suggests its a bios feature which can be altered by flashing.
I see what you mean. Do they touch when you spin them? Or can you pop them into place?
If not, I'd just power it up. I'm sure they would be fine.
I popped it into the system. Instant coil whine, it's clearly a return.
RMA time.
This has put me right off the G1 Gigabyte.
What's considered the best card in terms of silence, warranty and has the ability to overclock with the best of them?
RMA time.
Msi 6g.
Just wish I could have a custom fan profile along with the auto on and off of the fans.
Msi 6g.
Surely you can just set the fan to run at 0% until the card gets to say 50c?
, aside from a few AAA games many seem to run fine without boosting & the cards are totally silent.Is the MSI 6G a 2 slot card or a 2.5 (and thus 3) slot card? I need a thin-ish card for my current mobo else it goes over the SATA slots.
I'm not sure if I'll be able to return mine and part exchange it for another brand, because I cannot really be bothered going through a refund and all that. If not, I'll just go through G1's until I get one without coil whine I guess.
RMA time.
There should be a sticky that just says MSI G6 is the quietest 980ti and not far off the fastest. Its the best one out there IMO. Fans are barely audible at 70%
I'm not taking another chance on it. These cards should be B grade, they shouldn't be sending out 2nd hand returns at £600 a pop. It's just wasting everyone's time IMO.
Mine was brand new, I can't fault that, but the coil whine is very annoying.
My problem is no spare GPU so I'm going to have to buy something to get me by for the possible weeks I'll be without a card.
