Ah not very far then! Tired of it or had problems?![]()
Sorry Roady, I don't get what you mean
I must admit, your cycling did look quite skillful.
There isnt much room for error in some areas of that video so Kudos to you lol.
3 times in 12k miles isnt bad at all!
Lights are always a good idea, i dont use mine as much as i should. I use them when the weather is bad or on the darker mornings and evenings.
I havent used them in months now though.
So what are the other options at that price point then? Powertap wheel? I assume that would be unaffected by left/right variance?
Sorry Roady, I don't get what you mean![]()
I use them all the time, it's just.. easy? and if it helps even a little, I'll have them on.. front and back!
As time marches on crank based systems will continue to reduce in price as well imo as competition increases.
In a roundabout way I was asking why you were changing the frame!![]()
I'm the same with my rear, I'll generally turn my front on when traffic is bad and/or visibility isn't 100%. For what it takes to run USB chargeable lights with 2+ weeks run-time I consider it an 'easy' way to increase my visibility on the road. Removing and refitting lights is part of my preparation 'routine' (included with fitting VIRB, 810 and saddle bag).
Which front light are you using grudas? I've a Cateye Rapid X mounted on my headtube but considering fork mounting it... Want to keep my bars semi-clear as with the garmin/VIRB outfront and 2 bar mounted front lights in the darker weather space is at a premium.
Here's hoping!![]()
Right...question for you all about power meters.
How much is a G3 powertap build on a mavic open pro rim worth? good condition, ~18 months old.
J
Signed up for this years Coast to Coast In A Day sportive. 153 miles with 14,000ft of climbing. Really glad that I'm doing this with my club and not solo!
Haha You've lost me. Or I'm just being slow. I thought we were talking about tyres?![]()
this little beast! epic bit of kit IMO![]()
I'd heard the clips were not very good/broke/wore out?
Visor might be a good choice if you're having to wear glasses but I would check in a LBS for clearance as you might find you can't get your specs on underneath!
Guards, I'm in the process of retiring the ones I've recommended up until now - SKS Raceblade Longs. The clips on the guards (which make them removable) will eventually wear through (The clip mechanism just not robust enough and poorly designed so tight clearance and tyre rub ruins the clips) and you're then left with guards held on by zip ties (like my rear currently). The time I've spent fiddling with them so far would have been better spent adjusting a set of SKS Chromoplastics (trimming them to fit). I'm probably buying a pair of them shortly as my RB's days are numbered.
105km of climbing! Fun times...
Having been to the top of that Gorge on a Scooter it is indeed an awesome sight but I genuinely don't think I could get up that on a bike.
thanks I guess, I do get a lot of hate but I know the risks.. and crashing on a bike I guess I'm the only one who's going to get hurt?
3 times in nearly 15k actually!I use them all the time, it's just.. easy? and if it helps even a little, I'll have them on.. front and back!
You need lights for your kind of riding and the area, you need to stand out as much as possible, every had anything clip you?
What camera do you use by the way, i like the quality of it.
yeah I guess if I was riding around country-side/country lanes I'd be ok without lightsbut If I want to filter around like I do, keep the pace up etc I need some extra "oh" coming from me ha.
clip me no, but I had a woman in 4x4 run into me twice at the traffic lights! sitting there, waiting for green... bam from behind! how the hell?
garmin virb, still no change! good battery life and quality, plus it's less £100 notesawesome thing is that you can configure it to start when you press "start" on your garmin and stop when you press "stop" on the garmin too.. or navigate to camera "screen" on garmin and take pictures by tapping on the picture button - on garmin that is.
Want to ride the South Downs (100miles) on my CX bike next week, but I've suffered a few punctures on it, so was going to use some self seal inner tube to try to avoid any stops if I can. But I have no ideas what's good, found some nutrak ones on evans. 700x35. Any recommendations?
Need some help on choosing new wheels. I have narrowed it down to the 7 on this link: http://www.wiggle.co.uk/sale/cycle/road/wheels/?ea=4294767022&mi=150&ma=250&omi=20&oma=1940&cc=GBP
Which would be the best option? I've heard good things about the Zondas.
They need to be compatible with the Shimano Ultegra 6800 11 speed.
can't be right? I unclip mine a few times a day, swap between bikes when I go to gym etc and I've had it for 6ish months now? still as strong clip-in as it was day one.
Wonder if the Garmins are more accurate, been told they are?
Just gonna quote this, as could do with ordering some tonight and no responses :'(
