So Jambo, Did you receive your D7000 or were you lied to?
Price has now also dropped at the rainforest too, release date still shows the same though.
Mine arrives in an hour
Will let you know how it performs )))
)NETGEAR have a very poor history of supporting their devices. Good luck all.
How recent would yo say? Not used any netgear stuff since about 2006-7 never had any problems with it personally?
PING 31.55.184.248 (31.55.184.248): 56 data bytes
64 bytes from 31.55.184.248: seq=0 ttl=61 time=8.275 ms
64 bytes from 31.55.184.248: seq=1 ttl=61 time=8.703 ms
64 bytes from 31.55.184.248: seq=2 ttl=61 time=8.155 ms
64 bytes from 31.55.184.248: seq=3 ttl=61 time=8.198 ms
--- 31.55.184.248 ping statistics ---
4 packets transmitted, 4 packets received, 0% packet loss
round-trip min/avg/max = 8.155/8.332/8.703 ms
	Stats recorded 18 Jul 2015 13:36:03
DSLAM/MSAN type:        	BDCM:0xa48c / v0xa48c
Modem/router firmware:  	AnnexA version - A2pvbH042b.d26b
DSL mode:               	VDSL2 Profile 17a
Status:                 	Showtime
Uptime:
Resyncs:                	0 (since 18 Jul 2015 13:24:02)
				Downstream	Upstream
Line attenuation (dB):  	9.3		0.0
Signal attenuation (dB):	Not monitored
Connection speed (kbps):	79999		19999
SNR margin (dB):        	9.6		15.3
Power (dBm):            	12.8		-5.0
Interleave depth:       	16		1
INP:                    	48.00		0
G.INP:                  	Enabled
RSCorr/RS (%):          	0.0000		0.0011
RSUnCorr/RS (%):        	0.0000		0.0000
ES/hour:                	0		12.8
	adslctl info --stats
adslctl: ADSL driver and PHY status
Status: Showtime
Last Retrain Reason:    0
Last initialization procedure status:   0
Max:    Upstream rate = 26113 Kbps, Downstream rate = 96469 Kbps
Bearer: 0, Upstream rate = 19999 Kbps, Downstream rate = 79999 Kbps
Bearer: 1, Upstream rate = 0 Kbps, Downstream rate = 0 Kbps
Link Power State:       L0
Mode:                   VDSL2 Annex B
VDSL2 Profile:          Profile 17a
TPS-TC:                 PTM Mode(0x0)
Trellis:                U:ON /D:ON
Line Status:            No Defect
Training Status:        Showtime
                Down            Up
SNR (dB):        9.6             15.3
Attn(dB):        9.3             0.0
Pwr(dBm):        12.8           -5.0
                        VDSL2 framing
                        Bearer 0
MSGc:           -6              26
B:              130             237
M:              1               1
T:              0               42
R:              8               16
S:              0.0518          0.3781
L:              21468           5374
D:              16              1
I:              139             127
N:              139             254
Q:              16              0
V:              14              0
RxQueue:                60              0
TxQueue:                20              0
G.INP Framing:          18              0
G.INP lookback:         20              0
RRC bits:               0               24
                        Bearer 1
MSGc:           186             -6
B:              0               0
M:              2               0
T:              2               0
R:              16              0
S:              5.3333          0.0000
L:              48              0
D:              3               0
I:              32              0
N:              32              0
Q:              0               0
V:              0               0
RxQueue:                0               0
TxQueue:                0               0
G.INP Framing:          0               0
G.INP lookback:         0               0
RRC bits:               0               0
                        Counters
                        Bearer 0
OHF:            0               360581
OHFErr:         0               7
RS:             109999232               2252829
RSCorr:         2               25
RSUnCorr:       0               0
                        Bearer 1
OHF:            89089           0
OHFErr:         0               0
RS:             1068327         0
RSCorr:         0               0
RSUnCorr:       0               0
                        Retransmit Counters
rtx_tx:         356             0
rtx_c:          0               0
rtx_uc:         0               0
                        G.INP Counters
LEFTRS:         0               0
minEFTR:        79982           0
errFreeBits:    1746029         0
                        Bearer 0
HEC:            0               0
OCD:            0               0
LCD:            0               0
Total Cells:    220152157               0
Data Cells:     4017457         0
Drop Cells:     0
Bit Errors:     0               0
                        Bearer 1
HEC:            0               0
OCD:            0               0
LCD:            0               0
Total Cells:    0               0
Data Cells:     0               0
Drop Cells:     0
Bit Errors:     0               0
ES:             0               6
SES:            0               0
UAS:            35              35
AS:             1431
                        Bearer 0
INP:            48.00           0.00
INPRein:        0.00            0.00
delay:          0               0
PER:            0.00            3.98
OR:             0.01            64.22
AgR:            80614.82        20063.54
                        Bearer 1
INP:            4.00            0.00
INPRein:        4.00            0.00
delay:          3               0
PER:            16.06           0.01
OR:             95.62           0.01
AgR:            95.62   0.01
Bitswap:        11/11           1/1
Total time = 24 min 26 sec
FEC:            2               25
CRC:            0               7
ES:             0               6
SES:            0               0
UAS:            35              35
LOS:            0               0
LOF:            0               0
LOM:            0               0
Retr:           0
Latest 15 minutes time = 9 min 26 sec
FEC:            2               6
CRC:            0               4
ES:             0               3
SES:            0               0
UAS:            0               0
LOS:            0               0
LOF:            0               0
LOM:            0               0
Retr:           0
Previous 15 minutes time = 15 min 0 sec
FEC:            0               19
CRC:            0               3
ES:             0               3
SES:            0               0
UAS:            35              35
LOS:            0               0
LOF:            0               0
LOM:            0               0
Retr:           N/A
Latest 1 day time = 24 min 26 sec
FEC:            2               25
CRC:            0               7
ES:             0               6
SES:            0               0
UAS:            35              35
LOS:            0               0
LOF:            0               0
LOM:            0               0
Retr:           0
Previous 1 day time = 0 sec
FEC:            0               0
CRC:            0               0
ES:             0               0
SES:            0               0
UAS:            0               0
LOS:            0               0
LOF:            0               0
LOM:            0               0
Retr:           0
Since Link time = 23 min 51 sec
FEC:            2               25
CRC:            0               7
ES:             0               6
SES:            0               0
UAS:            0               0
LOS:            0               0
LOF:            0               0
LOM:            0               0
Retr:           0
NTR: mipsCntAtNtr=0 ncoCntAtNtr=0
	That sounds good then. A user on Kitz isn't impressed with his D7000 so I believe is returning it. I'll see how I get on with it when it arrives next week though. Glad to hear you seem pleased with it.
