Netgear D7000 VDSL modem/router
A likely story huh!
I'll look forward to your update when it arrives. If it is out on the date listed, I won't be able to purchase until September due to work commitments.
The German rainforest is now showing ready to be shipped in 2-3 days. Hopefully that means it will filter through to UK suppliers soon too. Need to get shot of this ASUS device ASAP.
That's good. I think the date will change as there will be 2 other UK suppliers as of Friday. One place already has stock but I wasn't too keen on their returns policy.
How recent would yo say? Not used any netgear stuff since about 2006-7 never had any problems with it personally?
The DGND3700 is a classic example.
The DGND3700 v1 was a horrible router, which NETGEAR never fixed. They then released a v2 which fixed all the issues and never rolled out any of the fixes to the older model.
I've used several NETGEARs and they all seem to suffer from poor WiFi range too.
So far so good, just as stable and fast on the VDSL side as the Netgear D6400 but with much faster boot up, web ui load up and the most awesome improvement is that when you apply 99% of settings it does not reboot the router, yay )))))
Also get better speed tests than the D6400 which I think is just down to the improved processor speeds, basically it can handle all the **** you throw at it.
Wireless speeds are amazing, tested it using my laptop with Intel Wireless-AC 7260 which is only 2 internal antennas and trying to download a 27GB movie form my Media Server from a room on a different floor and the other side of the house though 2 walls and a ceiling I was getting around 40 to 50MB/s so peaking around 400Mbit from a distance, tests to speedtest.net only added on around 2ms from LAN connection is this scenario also and download and upload where at max i.e. 74.99/18.76 etc so no loss there either.
So basically finally have a device that has all the speeds of the ASUS DSL-AC68U but with the Stability of the Netgear D6400, obviously not quite a customisable as the ASUS but certainly slightly more than the D6400.
If anybody wants any other stats let me know etc.
There is now a diagnostics page which is nice here is ping result form google.com IP.
Code:
PING 31.55.184.248 (31.55.184.248): 56 data bytes
64 bytes from 31.55.184.248: seq=0 ttl=61 time=8.275 ms
64 bytes from 31.55.184.248: seq=1 ttl=61 time=8.703 ms
64 bytes from 31.55.184.248: seq=2 ttl=61 time=8.155 ms
64 bytes from 31.55.184.248: seq=3 ttl=61 time=8.198 ms
--- 31.55.184.248 ping statistics ---
4 packets transmitted, 4 packets received, 0% packet loss
round-trip min/avg/max = 8.155/8.332/8.703 ms
Stats -
Code:
Stats recorded 18 Jul 2015 13:36:03
DSLAM/MSAN type:        	BDCM:0xa48c / v0xa48c
Modem/router firmware:  	AnnexA version - A2pvbH042b.d26b
DSL mode:               	VDSL2 Profile 17a
Status:                 	Showtime
Uptime:
Resyncs:                	0 (since 18 Jul 2015 13:24:02)
				Downstream	Upstream
Line attenuation (dB):  	9.3		0.0
Signal attenuation (dB):	Not monitored
Connection speed (kbps):	79999		19999
SNR margin (dB):        	9.6		15.3
Power (dBm):            	12.8		-5.0
Interleave depth:       	16		1
INP:                    	48.00		0
G.INP:                  	Enabled
RSCorr/RS (%):          	0.0000		0.0011
RSUnCorr/RS (%):        	0.0000		0.0000
ES/hour:                	0		12.8
Telnet Data -
Code:
adslctl info --stats
adslctl: ADSL driver and PHY status
Status: Showtime
Last Retrain Reason:    0
Last initialization procedure status:   0
Max:    Upstream rate = 26113 Kbps, Downstream rate = 96469 Kbps
Bearer: 0, Upstream rate = 19999 Kbps, Downstream rate = 79999 Kbps
Bearer: 1, Upstream rate = 0 Kbps, Downstream rate = 0 Kbps
Link Power State:       L0
Mode:                   VDSL2 Annex B
VDSL2 Profile:          Profile 17a
TPS-TC:                 PTM Mode(0x0)
Trellis:                U:ON /D:ON
Line Status:            No Defect
Training Status:        Showtime
                Down            Up
SNR (dB):        9.6             15.3
Attn(dB):        9.3             0.0
Pwr(dBm):        12.8           -5.0
                        VDSL2 framing
                        Bearer 0
MSGc:           -6              26
B:              130             237
M:              1               1
T:              0               42
R:              8               16
S:              0.0518          0.3781
L:              21468           5374
D:              16              1
I:              139             127
N:              139             254
Q:              16              0
V:              14              0
RxQueue:                60              0
TxQueue:                20              0
G.INP Framing:          18              0
G.INP lookback:         20              0
RRC bits:               0               24
                        Bearer 1
MSGc:           186             -6
B:              0               0
M:              2               0
T:              2               0
R:              16              0
S:              5.3333          0.0000
L:              48              0
D:              3               0
I:              32              0
N:              32              0
Q:              0               0
V:              0               0
RxQueue:                0               0
TxQueue:                0               0
G.INP Framing:          0               0
G.INP lookback:         0               0
RRC bits:               0               0
                        Counters
                        Bearer 0
OHF:            0               360581
OHFErr:         0               7
RS:             109999232               2252829
RSCorr:         2               25
RSUnCorr:       0               0
                        Bearer 1
OHF:            89089           0
OHFErr:         0               0
RS:             1068327         0
RSCorr:         0               0
RSUnCorr:       0               0
                        Retransmit Counters
rtx_tx:         356             0
rtx_c:          0               0
rtx_uc:         0               0
                        G.INP Counters
LEFTRS:         0               0
minEFTR:        79982           0
errFreeBits:    1746029         0
                        Bearer 0
HEC:            0               0
OCD:            0               0
LCD:            0               0
Total Cells:    220152157               0
Data Cells:     4017457         0
Drop Cells:     0
Bit Errors:     0               0
                        Bearer 1
HEC:            0               0
OCD:            0               0
LCD:            0               0
Total Cells:    0               0
Data Cells:     0               0
Drop Cells:     0
Bit Errors:     0               0
ES:             0               6
SES:            0               0
UAS:            35              35
AS:             1431
                        Bearer 0
INP:            48.00           0.00
INPRein:        0.00            0.00
delay:          0               0
PER:            0.00            3.98
OR:             0.01            64.22
AgR:            80614.82        20063.54
                        Bearer 1
INP:            4.00            0.00
INPRein:        4.00            0.00
delay:          3               0
PER:            16.06           0.01
OR:             95.62           0.01
AgR:            95.62   0.01
Bitswap:        11/11           1/1
Total time = 24 min 26 sec
FEC:            2               25
CRC:            0               7
ES:             0               6
SES:            0               0
UAS:            35              35
LOS:            0               0
LOF:            0               0
LOM:            0               0
Retr:           0
Latest 15 minutes time = 9 min 26 sec
FEC:            2               6
CRC:            0               4
ES:             0               3
SES:            0               0
UAS:            0               0
LOS:            0               0
LOF:            0               0
LOM:            0               0
Retr:           0
Previous 15 minutes time = 15 min 0 sec
FEC:            0               19
CRC:            0               3
ES:             0               3
SES:            0               0
UAS:            35              35
LOS:            0               0
LOF:            0               0
LOM:            0               0
Retr:           N/A
Latest 1 day time = 24 min 26 sec
FEC:            2               25
CRC:            0               7
ES:             0               6
SES:            0               0
UAS:            35              35
LOS:            0               0
LOF:            0               0
LOM:            0               0
Retr:           0
Previous 1 day time = 0 sec
FEC:            0               0
CRC:            0               0
ES:             0               0
SES:            0               0
UAS:            0               0
LOS:            0               0
LOF:            0               0
LOM:            0               0
Retr:           0
Since Link time = 23 min 51 sec
FEC:            2               25
CRC:            0               7
ES:             0               6
SES:            0               0
UAS:            0               0
LOS:            0               0
LOF:            0               0
LOM:            0               0
Retr:           0
NTR: mipsCntAtNtr=0 ncoCntAtNtr=0
That sounds good then. A user on Kitz isn't impressed with his D7000 so I believe is returning it. I'll see how I get on with it when it arrives next week though. Glad to hear you seem pleased with it.
I honestly think you will love yours, yeah but there are always people who are unimpressed with stuff, a dragon could fly over there house and **** money and rainbows and they would find fault :P
