What you guys make of this?
https://www.kickstarter.com/projects/819484536/lumos-a-next-generation-bicycle-helmet
Potentially £217.80 from Ribble with cashback.
Unconvinced, as drivers aren't trained to look for it.
I did the exact same switch, and it really confused me too at first. I've gone from that same combo to a regular ultegra BB with normal shimano cranks.
Only issue you'll have is finding somewhere with the correct tool to remove the BB! In the end a LBS removed it for me for a fiver so I didn't have to buy the tool.
It is simple. 386 is just a combination of a 30mm spindle from bb30 but with a wider shell more like traditional external cups, 68mm shell+width of cups, versus 68mm for bb30.
Remove old chainset. Fit new shimano threaded bb. Bbr60 or similar. Shooty in.
Back to this again, I've just had a panic whilst trying to remove my old chainset (what a pain that's turning out to be, need a bigger wrench!)
Anyway, I forgot to mention my bike has disc brakes and has 135mm rear dropouts. I stumbled upon the FSA site and it mentions this chainset is designed specifically for 135mm:
http://www.fullspeedahead.com/products/cranksets-road/gossamer-pro-bb386evo-db-2/
I can only imagine this is to do with the width? I'm rather worried that with 11 speed 105 I might have a few problems, should I be concerned?
I don't know what I'd do without the navigation (when exploring) sometimes on my 810. I guess I'd just be more lost!![]()
Love mine. Paid £80 in January and its been flawless.
It will fit on fine the only thing I've seen mentioned is potential chainline issues.
Some frames rub like hell as it is without wider rear spacing and I've had some that the chain tries to ghost shift to the big ring on it's own.
Fit it and see I guess.
your late Roady, we have always established I was wrong
Can I ask a favour guys, I think im doing ok, but can you check my profile
since back injury ive done 22 rides now, want to know if I am doing enough riding, for example, enough miles each ride / per week ? not enough rides each week ?
https://www.strava.com/athletes/1072386
Don't think I've ever had it where its been short enough not to last a long 3-4 hour ride unlss I've left it on by accident.
I used my 810 on a 20 minute commute with 2% battery showing.
It displayed 0% battery for 10 mins or more and continued functioning!![]()
