- 2 Jan 2012
- UK.
Still liking the 980 Ti. I think this one might be a keeper until Pascal etc.
I hope so. As you can see below, they are an extremely tight fit but I've finally got some support for them (very heavy cards) and tomorrow I'll finish getting everything setup and look at putting a fan at the end of both cards blowing cool air over them.
I ****ing *love* how chunky those heatsinks are![]()
It's just a shame motherboard manufacturers aren't a bit more accommodating when it comes to big chunky and powerful cards. What I find strange is that triple slot cards seem to have been around for some time but even boards that claim to be "gaming" boards can't really accommodate the best cards in SLI.
When it comes to PCI-E is there a reason why most boards won't allow the third slot to be used at 8x if the second slot isn't being used?
They are, it just depends what board/platform you're running.
Yeah I understand it does happen but thats my point, surely one of the most popular platforms for gamers must be z97? Asus and msi gaming boards must also be some of the most popular boards ?
There are plenty of boards with appropriate spacing. That is in z97 range.
You just need to consider such things prior to purchase of either motherboard or cards.
It's a lesson I am sure many an enthusiast has had to learn the hard way. For example, my board can take up to four cards, or allows for some major spacing, and gives massive flexibility. Also paid through the nose for it though.
My asus board has pretty good spacing for a second card, only one slot but still, better than the one posted above![]()
If your talking about the z97 pro gamer in your sig then it's exactly the same as my msi board in the picture above.
I put another card in mine and had a nice little gap. These are reference cards so only 2 slot. Guess that's it
Exactly, the amp extremes are triple slot
Return them and get a smaller, nicer looking card![]()
OK will do, on another note, is watercooling an option for these cards ?
Have you gone SLi too Sam?
