The Fury(X) Fiji Owners Thread
So what do I add in power limit and gpu clock settings?
Might as well bang power up to +50%, it just allows the card to draw more power if it needs it. GPU clock settings put to +5% for 1102.5
EDIT: I had no idea overdrive supported decimal %. Thinking about it now it makes perfect sense... DOH. As matt said 3.8% for 1090.
Try these settings and see how you go.
1090 Core
52c Target temp (should lock to around 51-50c in game)
100% max fan speed (fan speed will use just enough % to maintain 1090 core)
I think everyone whos got sick of waiting for em, has just gone Nvidia, as the Furys are still in stock, would have thought everyone would have just gone sod it, i'll get a non X instead, but been 10+ in stock of those since release day, and there can't be that many of them, as HBMs supposedly as rare as rocky horse ****, and theres only one brand of them as well because of that.
Theres a competitor now got the non Xs in, had them dated for sometime in August.
See how long they last.
Yeah. In which case thats basically a monopoly... at least in terms of developers and companies looking at it etc, no reason to care about AMD at that point. Real shame.
Yeah :(
Must be more to it than HBM, as theres more Furys than Xs.
I'm convinced that the random drops are caused by running more than one GPU, because I used to get that all the damn time on GTAV. They didn't drop to 0, but they did drop by about 15 FPS and even Gsync was having issues with it, so instead of a massive stutter I would get like a slow motion thing going on for a couple of seconds. Very odd !!
Any way, for the ROH here she is, safely nestled in.
I cut my finger doing that so I had to wipe all of the blood off but she's in. Coil whine on my PSU has dropped significantly, but then I expected that :)
Very happy boy, and a massive shout out to Greg for selling it to me and getting it here safe and sound :)
Just installing Wolfy now, will report back. I was getting between 23 and 31 FPS with it before on one Titan Black, so I'm pretty sure I can double that easy and it will actually be playable.
But yeah, god damn this thing is a 4k MONSTER.
Welcome and TROH updated.:)
The Roll of Honour.
24/07/2015, Make Reference, ALXAndy, Link
20/07/2015, Make Reference, Ash0787, Link
20/07/2015, Make Reference, phiiil, Link
05/07/2015, Make Reference, muziqaz, Link
30/06/2015, Make Reference, Gregster, Link
30/06/2015, Make Reference, Silent_Scone, Link
30/06/2015, Make Reference, MDPlatts, Link
30/06/2015, Make Reference, Firefox35, Link
30/06/2015, Make Reference, uksoldierboy, Link
29/06/2015, Make Reference, Sesta, Link
29/06/2015, Make Reference, TheSwede, Link
29/06/2015, Make Reference, whyscotty, Link
25/06/2015, Make Reference, Kaapstad, Link
25/06/2015, Make Reference, Boomstick777, Link
25/06/2015, Make Reference, machinebummer, Link
25/06/2015, Make Reference, AMDMatt, Link
To get on the Roll of Honour all you have to do is post a pic with your user name on it of your Fury X.
Isn't the rad supposed to go above the card (guessing for air buble reasons)?
It's a AMD reference design thing I'm afraid. AIB's take their own route and commonly disable the feature. Fury X owners will have it though and i highly recommend people use it. It's great if you have OCD about GPU temps and you have more than one GPU in the case. It helps me sleep easiery at night seeing identical GPU/CPU temps. :D:p
Back around the release of the 290s that wasn't how it worked for me on my reference cards.
The core clock would drop off quite wuickly as the fan didn't spin up fast enough so I think my core would throttle down to the 700s and then the fan would start increasing. Then when it got cool enough the core was ramp up again. But once it got to 947mhz it would get hot again and the cycle would repeat.
Has this really been fixed since the 290 release?
