Try 1090 on the core Andy. To go much higher you'll need voltage control, my worst card does 1090 24/7 stable.
Using AB?
Using AB?
So what do I add in power limit and gpu clock settings?
It does it with Hawaii too. My MSI 290x gaming results all say the clock is 1030 even if I have an overclock on it.
http://www.3dmark.com/compare/fs/3903833/fs/4283405
Can see Nvidia 90+ market share before long.
Yeah. In which case thats basically a monopoly... at least in terms of developers and companies looking at it etc, no reason to care about AMD at that point. Real shame.
I'm convinced that the random drops are caused by running more than one GPU, because I used to get that all the damn time on GTAV. They didn't drop to 0, but they did drop by about 15 FPS and even Gsync was having issues with it, so instead of a massive stutter I would get like a slow motion thing going on for a couple of seconds. Very odd !!
Any way, for the ROH here she is, safely nestled in.
I cut my finger doing that so I had to wipe all of the blood off but she's in. Coil whine on my PSU has dropped significantly, but then I expected that
Very happy boy, and a massive shout out to Greg for selling it to me and getting it here safe and sound
Just installing Wolfy now, will report back. I was getting between 23 and 31 FPS with it before on one Titan Black, so I'm pretty sure I can double that easy and it will actually be playable.
But yeah, god damn this thing is a 4k MONSTER.
Greg needs removing from there now![]()
Once you get on TROH you don't need to come off.![]()
It's a AMD reference design thing I'm afraid. AIB's take their own route and commonly disable the feature. Fury X owners will have it though and i highly recommend people use it. It's great if you have OCD about GPU temps and you have more than one GPU in the case. It helps me sleep easiery at night seeing identical GPU/CPU temps.![]()
