- 5 Sep 2011
- Surrey
GPU scaling in GTA V would have given you more than 42 average with two TITAN Blacks, Andy. You need go grab another to make it worth while
GPU scaling in GTA V would have given you more than 42 average with two TITAN Blacks, Andy. You need go grab another to make it worth while![]()
Did you want one then?
Any way, aside from that I just benched GTAV. I made sure the weather was the most punishing, then ran a 90 second benchmark driving around the town. Pic (note Photobucket will destroy it)
And...
Frames, Time (ms), Min, Max, Avg
4710, 90000, 45, 61, 52.333
As you can probably guess I am absolutely stoked. It ruins my Titan Blacks. They would go from anywhere between 37 and 52 FPS with a 42 average, now, even in the rain I'm getting 50s. Amazing card for 4k you really can't go wrong![]()
Theres a competitor now got the non Xs in, had them dated for sometime in August.
See how long they last.
Yeah
Must be more to it than HBM, as theres more Furys than Xs.
Yeah i want one, ive got one on pre-order, that sounds great for 4k, i get mostly around the 50s on my 290X, just about maxed out at 1440p, just got the MSAA off, and the Grass Quality on High, drops to around 46 when theres a lot of traffic about, but runs great, and smooth as hell using FreeSync![]()
What's stopping you, an AMD fetish....
Don't get the AMP. Get a reference card or anything else over it.
hahaha no way ! I know my screen is Gsync but I'm not changing it. Take away the frame dips from SLI and I don't really need it now.
I already have this..
https://www.overclockers.co.uk/showproduct.php?prodid=MO-065-AC
And...
So i don't get why Reviewers have the performance of it so low.
Does SLI work in GTAV?
Near perfect scaling for each card added.
