- 17 Jun 2012
Why are you being so defensive/aggressive?
I never called you an idiot, you said you were pinging stick back and forth so that's all I've got to go on.
Before I got my wheel I was playing fine with the 360 controller.
sorry, your reply was a bit patronising, I know pinging the stick around will cause erratic results, but as mentioned above fine feathering of any of the inputs with a controller seems almost impossible, which is fine for an arcade driver but a bit naff with a sim.
I reset my time without really thinking so had to set a time again - took that 4th place back by improving less than a second... including a barrel roll on the latter half of the stage
