- 7 Feb 2008
- Surrey
Did you not know that glutes are, in fact, for the slootes?
If I work my glutes they will steal vital nutrients which should be going to my biceps!
not srs
Please, its 2015. Glutes are so 2014, it's all about traps now.
Hammerite?
Hammerite?
No, it's favourable to brace your core properly & effectively. Holding your breath is something very different.
Admittedly the strength of the brace is increased while the diaphragm isn't moving as a higher intra-abdominal pressure can be maintained however you shouldn't need to hold your breath to achieve this and if holding your breath is how you go about achieving a brace it points towards not having got the hang of it.
Was thinking of trying something like that myself actually, maybe hang cleans to start. Mrthingyx will be proud.
Edit: this post is good place to start
1) Essentially impossible to lose fat and gain muscle simultaneously.
2) You should not be thinking that cardio = fat loss. Cardio is simply calorie expenditure and some fatigue, which is not a great look if you're trying to build muscle after an hour long recumbent bike slog.
OK thanks sorry for more noob questions...
So if it's impossible to loose fat and gain muscle what do you do? I mean do you gain muscle first and then look to loose the fat after? and if so how?
Nothing necessarily wrong with it, just be mindful that your trainer might be terrible. Look up form/techinque yourself.
Also, take responsibility for your mobility.
If you want to gain muscle you need to be in a calorie surplus, which means you need to bulk. When you bulk, some of the weight you gain will be fat and some will be muscle (provided you are working out enough to stimulate muscle production). The idea is you set a target weight at the start of your bulk and keep eating and training until you hit it.
Then you switch to cutting (calorie deficit) so that you can lose the fat and retain as much muscle as possible (some muscle may be lost if you do not work out enough or if you cut too many calories). You keep doing the same training during cutting, all that should change is the calories you consume, and you should lower this by reducing carbs (protein and fat should remain the same).
You can read more about this here if you are interested: BodyRecomposition. Lycle McDonald recommends first cutting to 10% bodyfat then bulking to 15% then cutting back to 10% and so on. This should lead to optimum muscle gain in his opinion.
Yeah I've had a good gander at the form thread, at the moment I'm just so far off in so many areas I need help to make a start.
The same with mobility really - I know that I have issues, but there are so many differing opinions out there around exercises / stretches to do to make improvements I'm a little lost with it all.
My back is dead. My thighs ache. But I feel awesome.
Managed to get a 65kg clean for 1 rep. Not bad for just my second session.
How does it look?
http://forums.overclockers.co.uk/showpost.php?p=28387705&postcount=88
Naww...I have a friend who's done some CrossFit before and he said it looks ok!
What's wrong.. or if it's easier what's right with it?![]()
Therein lies your problem.
Oh no he didn't!!!
