It just shipped
As for your Corsair link problem, Just don't use it.
I have all my fans plugged into my motherboard and just set to silent in the bios![]()
yeah I will have to fiddle around with it.
It just shipped
Clubs finally growing![]()
I'm a total convert though, I sold The Titan X to get the Fury X *Queue Evil Traitor Music*![]()
Technically it's an upgrade. Performance is similar but the Fury X is certainly a lot cooler and quieter under full load.![]()
Run!
Matt what settings are you using on GTAV bud? you on Windows 10? The problem is fixed if i disable crossfire but my fps are total crap.
Hold on mate, I'll grab some screenshots for ya.![]()
Can only imagine the performance of GTA V on 2x FXs, it runs superb on my 290X![]()
With two Fury X you can add x2 MSAA and dial up all the other (not advanced) effects to maximum.
Christ for over a thousand pounds bud i want my games maxed out! lol
2560'1440P i have everything maxed, did use AMD CHS shadows but it causes block shadows instead, advanced i run all maxed out -frame scaling.
Not going to happen on two gpu's bud, it's why 4GB is sufficient for 4K, even with two gpu's. To use more than 4GB consistently you'll need three or more gpu's at 4K.
That said i tune my settings to keep certain FPS ranges so I'm always in the (FreeSync) range.![]()
How about everything maxed out at 4K including in the advanced tab minus any type of AA, What sort of performance would we be looking at for a single Fury X ?
