- 5 Sep 2011
- Surrey
Should be fine. An AIO won't resolve VRM temperature anyway, you'd need to actively cool them with a fan.
So after flashing my bios I'm happy with the extra performance and think this is the way I want to run my card 24/7 but temps get up to 84c which I believe it is ok on stock cooling but everything's very loud now and I'm a little worried about the VRam temps.
So who would recommend the Hybrid EVGA cooler?
What would this bring my 84C max temp down by and the noise? Will it help Vram temps?
Also where should I fit it in my case? A B or C? I have a H100i cooler strapped to the top of the case so it can't go there.
And are they out of stock everywhere?
I got mine properly idling again so I am back to 30C idle, I have to rev my fans up a bit to keep 1500/8000 cool during my longer sessions as I only have a single 120mm radiator but I still keep it below 60C.
Not really room to add in a larger radiator![]()
Well if you must build your PC in a bread bin...![]()
Would a Titan X work well with Skylake i5 6600k
Is there a selling forum on here as I'm looking to sell my TX?
